    Claes
    Mark
    Felmeddelande vid byte av skivor belägg bak Tiguan 18
    Har problem med handbroms mm efter bytet ,gjorde allt efter Ross-techs guide.Även om allt inte stämde på deras video(dom kör gammal (15) version i videon.)jag har 22
    Får detta vid körning
    Sunday,28,August,2022,15:00:31:47336
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 22.3.1.4 (x64) HEX-NET2 CB: 0.4615.4
    Data version: 20220407 DS337.0
    www.Ross-Tech.com
    VIN: WVGZZZ5NZJW326615 License Plate: YPW686G
    Mileage: 37798 Repair Order:
    Address 03: ABS Brakes Labels: 5Q0-907-379-IPB-V1.CLB
    Control Module Part Number: 5Q0 614 517 CF HW: 5Q0 614 517 AD
    Component and/or Version: ESC H25 0513
    Software Coding: 0AEE6B9A54222372477D070162C84950D62AC4E2E046927D38 425078C22A4200002F641A1B13111435351919323200
    Work Shop Code: WSC 01357 011 00200
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010 (VW37)
    ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
    VCID: 77A0835ABF46CA33FE5-8022
    1 Fault Found:
    32951 - Control Module for Electronic Parking Brake
    C10E2 54 [136] - Missing Calibration / Basic Setting
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 32
    Mileage: 37798 km
    Date: 2022.08.26
    Time: 14:59:38
    Sen detta Efter att jag kört test efter att problemet kom tillbaka.
    Wednesday,31,August,2022,18:15:24:47336
    www.Ross-Tech.com
    Address 10: Park/Steer Assist Labels: 5Q0-919-298.clb
    Control Module Part Number: 3Q0 919 298 B HW: 3Q0 919 298
    Component and/or Version: PLA 3.0 12K H09 0029
    Software Coding: 0231563A51
    ASAM Dataset: EV_EPHBO2CVW3260000 010016 (VW37)
    ROD: EV_EPHBO2CVW3260000.rod
    VCID: 3C2A5C76C6E0296BD37-8068
    1 Fault Found:
    13637120 - Databus
    U1123 00 [008] - Received Error Message
    [Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 32
    Mileage: 37798 km
    Date: 2022.08.26
    Time: 14:47:36
    och denna
    Wednesday,31,August,2022,18:17:30:47336
    www.Ross-Tech.com
    VIN: WVGZZZ5NZJW326615 License Plate: YPW686 NEW
    Address 03: ABS Brakes Labels: 5Q0-907-379-IPB-V1.clb
    2 Faults Found:
    32800 - Supply Voltage for Left Parking Brake Motor
    C100D F0 [137] - Short Circuit
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 247
    Mileage: 37798 km
    Date: 2022.08.29
    Time: 18:15:39
    32801 - Supply Voltage for Right Parking Brake Motor
    C100E F0 [137] - Short Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 247
    Mileage: 37798 km
    Date: 2022.08.29
    Time: 18:15:39
    Claes
    Mark
    Å då körde jag en full kontroll
    kolla txt fil
    Bifogade filer Bifogade filer
    Har du provat att radera felkoden? Och de andra felkoderna?
    Din bil är en MQB bil. Jag har bytt bakre pads på Golf och Seat bilar 2014 respektive 2018 som bägge är MQB bilar. Har använt VCDS på Golfen och OBDeleven PRO next gen på Seaten. Bägge bilarna har genererat felkod i modul 03 i samband bytet. Jag följt proceduren man som man ska (Start lining change mode/End lining change mode). Jag raderade felkoden ifråga som inte kom tillbaka. Allt ok efter det. Kan inte säga var det var för felkod tyvärr.
    Du har ju flera andra felkoder enligt bifogad fil som inte har med denna reparation att göra, dem går jag inte in på.
    Claes
    Mark
    AndySwede
    Jag har raderat felkoden för bromsen. Även kört funktions testen för broms mekanismen i vcds.
    Den säger att allt är ok ,sen funkar det några gånger med i & ur av e-bromsen.
    Peter-C
    Jag vill inte *tömma* koderna innan jag kollat upp alla.
    1 ev 2 fel hör ju till E-broms felet (typ auto hold).
    Problemet är ju att den säger att den inte är kalibrerad H-bak först,**32951 - Control Module for Electronic Parking Brake
    Sen körde jag testet & allt var ok.
    Allt funkar & låter som det ska ett par gånger , tills det att e-bromsen blinkar och säger typ *broms servo fel* i instrumenteringen.
    Nu funkar inte bromsen att lägga i igen utan blinkar bara...
    Då kör jag testet igen & får
    felmeddelandet 2 kortslutning på bägge bak??? Fortfarande hör jag dom snurrar i oken.****32800 - Supply Voltage for Left Parking Brake Motor
    C100D F0 [137] - Short Circuit + 32801 - Supply Voltage for Right Parking Brake Motor
    Har testat att radera detta också men då kommer vi först tillbaka till kalibrering igen .
    Så det är som en ond cirkel...
    Okay. Hö/vä sida "kortslutning" säger den. Har du kommit åt någon kabel till handbromsen? Annars vet jag tyvärr inte vad man ska gå vidare med, har ju ej haft detta problem.
    Claes
    Mark
    Problemet är att allt låter som om det funkar , E-Bromsen tar också.
    Så ja tror inte på kortis, eftersom den kan göra testet.
    Bara för att vara extra tydlig. Denna procedur har jag praktiserat genom åren. 6 år gammal tråd.....
    https://www.gtiklubben.nu/forum/show...l=1#post229502
    Vi får väl se om någon annan har lite med input för att skapa klarhet i ärendet .
  1. Svar: 0
    Senaste inlägg: 2022-03-12, 20:53
  2. Byta skivor och belägg Golf GTI 7
    Av RNEH i forum VW-forum
    Senaste inlägg: 2018-04-10, 11:11
  3. passat 2012 byte av skivor belägg bsk
    Av wrom i forum VW-forum
    Senaste inlägg: 2014-07-24, 08:40
  4. Skivor/belägg till IV r32
    Av Exelon i forum VW-forum
    Senaste inlägg: 2010-07-09, 23:15
  5. Dax för byte av skivor och belägg GTI-88
    Av Fenix i forum VW-forum
    Senaste inlägg: 2007-11-27, 17:57
